Help!!
killa0098
hi all, i got a question have read a few threads on this but i still cant figure it out, the constant 12v source in the wiring harness on my 1986 f250 isnt keeping ne of the settings on my headunit, when i dosconnect it the unit wont turn on, when it is connected it will turn on, but it loses all settings after i shut the key off, i have also tried running a wire back from the battery and that hasnt worked either, please help
there is a constant 12v, and an accessory 12v. the acc wire comes on with the key switch. the constant is just that, constant. and that should keep your settings. are you running these 2 wires separately? or maybe you have them backwards? some folks run them all together. those are the folks who have these kind of problems, no offense.
177
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
535
376
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
364
killa0098
killa0098
United States
mylows10
    May 16, 2024
    May 16, 2024
