Help!
cgriffin224
So ive got my whole system hooked up in my room. Its running off a power supply hooked to the wall, but that doesnt have anythign to do with the problem. So I got my new Alphasonik 4150 amp today, and when I plugged it in i was happy to see the light turn on. When I went to wire up my deck, all went well until I plugged the ground back into the power supply negative terminal. The whole amp shuts right down, but the deck starts up. Any ideas what the problem could be? I unhooked all speaker equiptment, and tried it that way and still the same thing....
Thanks,
Chase
25 amps at 120 volts AC is a lot different than 25 amps at 12 volts DC.
You should always fuse your wiring when you change size or voltage.
what did you do for a remote turn-on? from the head unit?
what power supply are you using? model number?
verify with a DMM the voltage at the amp battery, remote, and ground terminals.
cgriffin224
cgriffin224
Boyne City, Michigan
keep_hope_alive
