help
listen retard... drill tight holes for the bolts you selected... go get some wire and some wire crimpers. and some ring terminals. Biggest you can find to go over the bolt you will be using. Make sure you use flat washers to protect the box and ring terminals and locking washers on the very ends of the bolt. Make sure you figure out your impedance load first. final load your amp will see. gl
Pauliesnite93
Pauliesnite93
Temperance,MI
Pauliesnite93
