Help
ok I just installed my amp and subs and for like 5 mins it was working great then all of a sudden the amp goes into protect if i turn it up loud so I was thinking it might be a ground problem anyone got any input?
check the ground.. possibly low voltage? i know thats happened to me before..also dave (pioneerpimp)
for giggles -
run a piece of ok sized wire from the negative on your battery, ( externaly this is a test still )
and hook it up to your amp ( along with your current ground wire )
and see if it still goes in to protect mode.
also, pull out your speaker wires from the amp, and check em with an ohm meter.
just to make shure that they are still at the propper ohm value.
for giggles - run a piece of ok sized wire from the negative on your battery, ( externaly this is a test still )
"RESISTANCE"
Jason19
Jason19
Kenosha Wisconson
Jason19
