help
jv032889
can this amp Pioneer GM6100F power the infinity reference?
Specs
CEA-2006 Compliant Amplifier Power Standard:
60 Watts x 4 @ 4 ohms
150 Watts x 2 @ 4 ohms BRIDGE
80 dBA Signal-to-Noise Ratio
Peak Music Power: 120W x 4 (4 ohm) / 300W x 2 (Bridge 4 ohm)
4 Channels
Continuous Power @ 4 Ohm: 60W x 4
Continuous Power @ 2 Ohm: 75W x 4
Continuous Power Bridged @ 4 Ohm: 150W x 2
Frequency Response: 10Hz-50kHz
THD (1kHz, 4 Ohm):
Signal to Noise Ratio: >95dB
Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
PWM Regulated MOSFET Power Supply
Balanced Isolator Input Circuit
Oversized Screw-Type Power/Ground Terminals
4 Channel RCA Inputs
RCA Outputs (Pass Thru)
Speaker Level Input
Screw-Type Speaker Terminals
Hi-Volt Input Level Control (200mV-6.5V)
Selectable Crossover (80Hz, -12dB/Oct.)
Pioneer 1-Year Warranty
infinity reference
Speaker Size 6 1/2
Design 2-way
Tweeter Design 1" Dome
Tweeter Composition Edge-driven textile
Woofer Composition IMPP
Woofer Surround Hi-roll rubber
Specifications
Sensitivity 93 dB
Frequency Response 53 - 21k Hz
RMS Power Range (Watts) 2-90
Peak Power Handling (Watts) 270
Impedance (Ohms) 2
Top-mount Depth (Inches) 2
Cutout Diameter or Length (inches) 5 1/16
jv032889
jv032889
florida
Fusion_FREAK
