Help?
Answer:
-What kind of music do you listen to?
-Who is installing (you, you and a friend, or a shop)?
-Do you want just a new head unit, just sub(s) and an amp, or...
a complete system with new front speakers and an amp to power them?
-Do you want it to just be obnoxiously loud, or give up loudness for sound quality,
or do you want a good mixture of both?
-If you are taking it somewhere to have it installed, does that $600 include installation?
Those should keep you busy for a while...answer those questions and we can help you more...
-I listen to rap
-just wanting subs and amp
-goin to have a shop install($600) does not include installation fees
-want a mixture of both loudness and sound quality
was looking at the pioneer premier TS-W3001 D2
Sensitivity: 89 dB
RMS Power Range : 1000 Watts
Peak Power Handling: 3000 Watts
Impedance: Dual 2 Ohm
Low Frequency response: 18 Hz
High Frequency Response: 700 Hz
Diameter: 12 Inch
Not sure which amp would work with these tho
actually its a CDX-GT300
Details:
CD player with built-in amplifier (17 watts RMS/52 peak x 4 channels)
plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3, WMA, and ATRAC3plus music files)
EQ3 (seven preset tone curves and a 3-band equalizer)
Dynamic Soundstage Organizer
BBE MP
24-bit digital to analog converter
two sets of preamp outputs (rear outputs can be switched to subwoofer mode)
subwoofer controls
front-panel auxiliary input
CD changer controls
satellite radio-ready (XM or SIRIUS tuner, subscription, and antenna required)
CD Text compatible
detachable face
CEA-2006 compliant amplifier
clock
SSIR-EXA AM/FM tuner
18 FM/12 AM presets
seek tuning
remote control
CD frequency response: 10-20,000 Hz
CD signal-to-noise ratio: 120 dB
FM sensitivity: 9 dBf
warranty: 1 year
bballshortie64
bballshortie64
mEMPHIS
bballshortie64
