Help!!
BigAl
I have two jl w3v2 d4 12's on a lanzar 1400d opti. I got the amp on 0 guage wire and wired the subs to run on 1 ohm. The amp keep shutting down and the bass comes on and off. I thought the amp was bad but I got another one and it does the same thing. Also there was a loud pop. The subs are fine, I put them on another amp and they run fine. The amp is supposed to be stable at one ohm. I dont know what's going on. Help
Check your subs if you havent yet, and see if all the wires are in tact.
Check your amp wires as well, possibly your ground or power connections could be comming off- check at the batt terminals too....
BigAl
BigAl
birmingham,al
LOUD 4DOOR
