Darren5531
I finally got both my sub( 15" tc9) and my amp (rockford fosgate 225.2) and I went to put it all in and I turned it on and my sub isn't working. I know my sub works cause I have tested it out on 2 other amps plus hooked it up to my normal speakers just to make sure it was still working. I have a shosche wiring kit. power wire from battery to fuse block. From fuse block to distro block. From distro block to amp. Then I have my ground from the amp to the nut on the chassis. I have the rem wire wrapped around the post where it is and hooked up to the cd player. I have the rca blue to positive white to negative and connected the same way to the amp. I have the sub wired to 4 ohms ( - to +, + to + on amp, - to - on amp). I even tried just wiring it into 1 channel of the amp and still nothing. I just orded the amp from Xavierracing, he is also selling a broken one could have it been possible that he just shipped the broken one istead of the working one? I can take pictures if you think I did my wiring wrong. Please anything that I did that I could try and see if it works please let me know. When I turned my car on the amp led light didn't come on so Im thinking its either with the wire or the amp.
THANKS,
Darren
THANKS,
Darren
