Help
jeep
i just got a pair of jl VR componets and im going to pick up another pair of jl coaxial speakers tomorow im putting the componets in the front and the coaxial in the back. i was wondering if i should get a amp for just the front speakers and run the rear speakers off the head unit or if i should get a four channel amp and run all of the speakers to the amp. please help there in a jeep grand cheroke if wondering thanks.
My opinion...definitely run the comp set off an amp to get the full benefit. Rear fill....I wouldn't run them off the amp..then again I also have the 4 10w0's so the bass would probably drown them out...
Dave
123
436
411
jeep
jeep
Easton PA
NJAV1
    May 31, 2024
    May 24, 2024
