Help!!!!
  • 4
dont buy that. 4 or 2 ohm l5's?? if 4 ohm get a monoblock that puts out around 1500rms @1ohm... if theyre 2 ohm, get a amp that puts out around 1500 watts @ 2 ohm
alright what is OHM? and 2nd these r the exact specs, 3rd if this is crap, tell me what amp i should get
ROCKFORD FOSGATE MODEL # 501X
1500 WATTS MAX
250 WATTS RMS X 2 INTO A 4 OHM LOAD
125 WATTS RMS X 4 INTO A 2 OHM LOAD
65 WATTS RMS X 4 INTO A 4 OHM LOAD
BUILT IN FIXED 12dB ELECTRONIC CROSSOVER
please help
oh, well if the subs are a dual voice coil 4 ohm voice coil, i have an amp that will put out 1000 watts RMS @ 1 ohm ( which you could hook both four ohm voice coils in a configuration that would come out to a 1 ohm load.) lol sorry if this is confusing im trying to put in in as simple as terms as possible. let me know if youre interested i can PM you information and a price
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i gotta get a bigger amp anyways
it says
SoloKon 1 piece cone
Rear Cone Brace
Increased Santoprene Surround Radius
New Enhanced BAM (Basket & Motor) Assembly
Perimeter Venting in the BAM
Dual Ultra-Length Voice Coils
High-Temp Polyimide Film Voice Coil Former
Sleeved High-Power Tinsel Lead Wires
Dual 4-ohm voice coils for wiring flexibility
Frequency response 20-100 Hz
Power range 50-600 watts RMS (300 watts per coil)
Peak power handling 1200 watts
Sensitivity 87.9 dB SPL
Top-mount depth 6-3/4"
376
321
333
bumpin_tahoe
bumpin_tahoe
Lexington, KY
NhustlaR
    May 24, 2024
    May 23, 2024
