Help with wiring system / where to find 1x0awg in 4x4awg out fuse block
I'm fixing to finally install my system, but I'm stuck amassing all the little bits and pieces. I'm going to do a battery relocation (for future use), so I don't know exactly what connectors and fittings I need for that, but there's a bunch of writeups for that so I can figure that part out for myself. However, I can't find a fuse block that'll work for me. Right now I have 1/0 gauge cable going from my batt to my amps, two of them right now, both of which I want to run 4 gauge to. However, I'm likely also going to add another amp for rear fill, a computer (OPUS 320W, 8 gauge probably), and a bunch of other peripherals. I figure I can run the 0 gauge to a 4x4 gauge fuse block, going to the three amps and a 4 guage in 4x8 gauge out fuse block, and that should give me plenty of room to play. I can find 1x1/0 -> 4x4 ground blocks, but no fuse blocks seemingly no matter where I look. Anyone know where I can get one, or if I should do it differently some how?
Additionally, for the battery reloc, how big should my fuses be? Should I have one at both ends of the main run? Should I also have a fuse going from my batt to the main fuse block? How big should that one be?
If you plan on using all 4 4ga outs, you might think of running another run of 1/0 and using two 1/0 in 2 4ga out. Not sure on the specs of your amps and stuff, but it coudln't hurt to have more power running to the back.
I've nver seen a 4 4ga out fused distro. Only seen the ground blocks. I actually have one that's 1 1/0 in, 6 4ga out.
spinlock
spinlock
Jacksonville, FL
budget76
