cobra65427289
i am a little confused about wiring these bad boys up, i just ordered 2 eD k's dvc 4 ohms. how can i wire two 4ohm dvc subs into 2 ohms with a 2 channel amp? do i just bridge the amp and just wire the same way i would with a usual dvc 4 ohm setup? if you dont understand a question just post how you would wire 2 dvc 4 ohm subs from a 2 channel amp that is bridged to be puting out a 2 ohm load. a picture would help. thank you
