help with wireing
Wire the positive from VC1 to the negative of VC2 on both subs. Then connect the positive and negative of one of the subs to the rear channels bridged, it should tell you which terminals to use on the amp. Do the same for the other sub except on the front channels.
DISREGARD THAT, I thought it was two subs.
You can either hook up each VC of the sub to a channel on the rear set or wire the sub like above, and bridge it to the rear.
astrovanman
astrovanman
LA,CA
squeak12
