help with the firewall
Look for a stock grommet there usually at the top once u find it take a coat hanger bend it in half so that the coat hanger is straight. Go inside the car making sure to pull off your interior moldings first pull back the carpet then tape the coat hanger and tape it to the wire push the coat hanger down into the grommet with the wire taped to it. This will get the wire in the car from there and just run the wire to the back like normal.
yup np evan works with anything u gotta fit through . Just make sure that the tape is very tight around the hanger/wire that way it does not come off when you go to feed it through.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif gl man.
evanhurford
evanhurford
Independence, KS
audiobahnuser18
