Help with subs, not hitting same time. <3
kgcolbyIII
Ok, i was going to sell these subs but iv noticed its having an issue that i thought went away
When the bass hits they dont both go out even. They both go out at the same time but one goes out more and ***** the other one right in. Its ok on medium volume but high volume it makes the weaker one clap.
I tested with a 9v battery and they are not out of phase
the box is 100% sealed and even made a silicone gasket underneath the subs for a complete seal
have you made sure that the tinsel leads are not messed up on one of the subs. Assuming there dual inputs. Might also get a multi meter maybe one is a different ohm load. might also have one that is on its way out.
Single chamber, you know what.... Its possible that one lead could be backward. Both tested fine for current but maybe one is in reverse but if that was so then the 9v trick would not work right?
check the coil resistance with a digital multimeter. one might be at 4 ohms and one might be at 2.. the 2ohm load will get more current and wang harder than the other sub.
Probably won't hear now till Monday but during the week they respond in a decent time. Also send a msg via facebook if you haven't as I usually...
777
You could do the 8" as a front sub on its own amp and use it to bridge/enhance the gap between your 12" in the rear to the midranges
658
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
kgcolbyIII
kgcolbyIII
oceanside, ca
skylineTT
DEW123
    May 7, 2024
DEW123
    May 7, 2024
