Help with subs, not hitting same time. <3
kgcolbyIII
Ok, i was going to sell these subs but iv noticed its having an issue that i thought went away
When the bass hits they dont both go out even. They both go out at the same time but one goes out more and ***** the other one right in. Its ok on medium volume but high volume it makes the weaker one clap.
I tested with a 9v battery and they are not out of phase
the box is 100% sealed and even made a silicone gasket underneath the subs for a complete seal
have you made sure that the tinsel leads are not messed up on one of the subs. Assuming there dual inputs. Might also get a multi meter maybe one is a different ohm load. might also have one that is on its way out.
Single chamber, you know what.... Its possible that one lead could be backward. Both tested fine for current but maybe one is in reverse but if that was so then the 9v trick would not work right?
kgcolbyIII
kgcolbyIII
oceanside, ca
skylineTT
