help with sub box in regular cab truck for sundown sa 12 please!!
boostindoo
im a long time lurker. havent had a vehicle to really put anything car audio in in awhile. this is also my first time putting a sound system in a truck. so if you guys could hook me up with some simple box designs and ideas that would be awesome!! i hope all the info i gave will be enough. thanks in advance for the help!! i havent gotten the sub yet, so if anybody has one they want to sell let me know...
Vehicle : 2003 dodge ram 1500 regular cab
Location in the vehicle: behind driver seat
Space available (Length x Width x Height): 31x12x16
Subwoofer make and model: sundown sa
Subwoofer Size: 12
Number of Subwoofers: 1
Type of Port (Kerfed, Slot, Aero, etc.): aero, slot
What type of music do you like?: decaf, dubstep, rock, hiphop
Is your goal SPL or Everyday Music?: everyday music
Tuning Freq (Hz): 35 or whatever is optimal
Volume : 1.5-2.0cuft
sub specs: * RE: 4.33 Ohms * Fs: 30.3 Hz * Qes: 0.519 * Qms: 7.25 * Qts: 0.484 * Vas: 29.07 L * BL: 22.16 NA * Le: 4.73 mH * Mms: 308 g * BL^2 / RE: 113 * 600 watts RMS * XMAX: 19mm one way
Mounting Depth = 6.5" Cut-Out = 10 15/16" Displacement = 0.14 ft^3 Overall OD with Gasket = 12.5" Enclosure Suggestions: 1.75 ft^3 ported tuned to 30 Hz -- F3 of 26 Hz * Tune higher and use a smaller box for more SPL oriented setup (Use 1 - 1.5 cubes) * Enclosure can be as big as 2.25 ft^3 with lower power levels 1.00 ft^3 sealed -- F3 of 44 Hz * For SQ and space limited applications
sub amp: sax 1200d
Questions: what would be the best orientation in a regular cab? sub forward, port to driver side panel?
sub forward port to the passenger side is your only option really. you gave dimensions for a square box, trucks use wedge boxes.
thank you so much guys!!
so, 26.5x12x16 with an aeroport 4x 6.35 would be about 2 cubes @ 32.....perfect!! my truck has a lot of space behind the seats for some reason. thats why im just trying to keep it simple and build a square box that would fit back there. im only 5'9 so i have plenty of room.
i had a question about changing the box dimensions...if i changed the dimensions a bit, say 26.5x14x14, would that still work? i need to build a second box for an acura tl...
As was stated, you need a wedge enclosure for a single cab.
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
549
boostindoo
boostindoo
United States
CSCStang
