Help With Port Tuning and Displacment
DangerRanger00
Single Cab FTL...
ok,
Some may remeber my thread on the blowthrough. well i have desited to go a diffrent route, insted of cutting a hole in the cab and bed of the truck i am still paying on(//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif). i came across a deal on a sung top for 100bux. i jumped on it.
now the problem is fig. up the port length and size for the box. i have desited on a sub up, port back design. the max dem. i can use is 40L x 40W x 15T, so i can still have a little usable bed space. the prob is that leaves me with gross. mesuremnt of 10.8cf witch is wayy bigger then i need.
the min airspace i need is roughly 8.5 after driver and port displacment.
the total driver displacement for the 4 drivers i will be using is .48cf. and the freq. i would like to have would be in the 30 to 35 hz range..
any input would be very helpful.
thanks
DR
was messing with that earlyer, but thats for a "L" shaped port. i was planng on going along the lines of a square port. (only box i can think of is meade's design 4 his tahoe)
whatever your port length is, just use the same length, straighten it out, that is what i done with mine. same space and all, u just have to make sure you have enough rm to straighten it out.
DangerRanger00
Single Cab FTL...
DangerRanger00
Hartselle, Al
DangerRanger00
michigan born
    May 14, 2026
michigan born
    May 14, 2026
