Help with new subs
bass-aholic
So ill be doing a new setup soon and need some help on new subs, ill have about 3000-4000rms depending on subs. I want to run either 2 18"s or 4 15"s. Currently thinking of doing 2 18" FI Q's again but would like some other options. Budget is $600 but i can go a little higher if its worth it and i can go up to 15^3ft. Also i would like to buy new, but again if its a good deal i will consider used. Thanks a bunch in advance!
Do you have an amp or are you going to purchase subs first? I would say try out some subs from Incriminator Audio. THey have 5 differet levels of subwoofers starting at around $120 for a 187 series 15". as far as bang for the buck goes, 4 - 187" 15"s with a amp(s) rated at about 2000-2500rms will be loud. Here is the plus side of staying close to 2000rms also, You wont NEED to upgrade your alternator if you have not already done so. It will help if you do but it wont be needed. So i would say alot of your decision has to do with how far you are willing to go. Staying in the same power range, you could do 2- Death Row 18"s also.
Hit up RIO or myself about the IA stuff or any other help or questions you may have. He is a dealer. I have 4- Deathpenalty 18"s in my ford ranger and a Death Row 18" in my Chevy.. Hell, maybe you can run some 21" subs...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
bass-aholic
bass-aholic
New York
SQcrewcab
Mike Mccabe
