Help with getting the right amp!
and i run a the saz 2000d.. so i know i was getting atleast 2000. but actuaslly my truck idles at 14volts so lets say about 2300 and this is on one mofo 15. i dont run 2 subs
Thats sweet. I currently have 2 L7's with a mtx 6500d amp. Sounds good. But I prefer sealed then ported.
Now that's a budget set up.. Way to much fail..
Yeah he is definitely cheap, he went to a sound off and got 144.3db he has the wrong boxes for them tho too small and probably tuned wrong I'm going to build him a new box when he has the money but yea definitely cheap the amp doesn't even have its own fuses which I dislike. He is using the stock head unit with a line level converter too lol.
Dont bash the MOFO's! I'm running 4 12's d2 vc's on 2 Bxi 2610d amps in an 8 cu ft ported box tune to 32hz with 3 Kinetik hc 1800's an Iraggi 300 amp alt, big 3 all 0 gauge. If you heard it without seeing it you would think I had higher end subs. BTW running each amp @ .5 ohm. Prob need 1 more alt.
DeathByWaffle
DeathByWaffle
Sheboygan. WI
LosIsATool
