cory51191
Cory
2 Hifonics 12" Zeus speakers DVC... 4ohm, 500rms, 1000w max.
Hooked up to a Fusion Power Plant amp... 2000w max. Sending 1ohm@1150rms.
i have 3 dials that i don't know how to set and a switch, please help me set them to get max power without doing damage to the subs?
-The switch can be switched to "0" or "180"(degrees)
(EDITED)
-1st dial: Bass Boost 0dB - 12dB
-2nd dial: LP: 40Hz - 250Hz
-3rd dial: SUBSONIC: 10Hz - 50Hz
4th dial: LEVEL: 0.2 - 8v
the only one i know how to set is the 4th dial, correct me if i'm wrong. (got directions from manual)
1. Turn the amplifier level to zero.
2. Turn the volume of the head unit to ¾ and the bass and treble to zero.
3. Adjust the level control until the desired maximum volume is achieved without distortion.
4. Failure to follow these steps may cause permanent damage to the audio system.
please help me with the rest of the dials
(EDITED)
