Help With Firewall on a 93 Civic
well your HOMEBOYZZ should look uder the hood where you see other stock wires coing out. look around the gas pedals etc.. tahts where i found mine and if all else fails, then you gotta drill
What size wire? If its smaller than 4 guage, I'm sure you can find a small hole somewhere, but if its big wire (4,2,0 guage), then I'd suggest drilling...
People run wire through the door, but that is a horrible idea...
i3abyjay25 - I saw a rubber grommet that was about an inch and a half in diameter right where u're talking about.. but when i pulled it out, there was metal behind it. And I'm trying to run 4 gauge wire, but i do have some 8 gauge, either one will work, I just need to get it to the amp.
TwiztedRolla
TwiztedRolla
Sunrise, Fl
TwiztedRolla
