help with eagle vision headunit please
hasa68mustang
I install alot of car audio in friends cars, and this one has me stumped. I got the factory unit out and went to put the new one in and discovered there wasnt enough mounting depth for it to go in. I was all for taking out whatever was in the way however it is part of the ac system I believe and was thick plastic that I didnt plan on cutting. The unit was a kenwood, and I guess my question would be are there any decks that are shorter that he could use? it needs to be about a half of an inch shorter Thanks, Tommy
are you using the chrysler kit? You can space it out a little from the kit with an ABS plastic piece cut to fit over the din opening in the kit.
Ill have to see about doing that... but thats a huge piece of plastic to get a half an inch... its reall closer to 1/4" but I just wanna be sure, I dont want to pull everything apart and have to do it all over again... even though its a pretty easy install
hasa68mustang
hasa68mustang
Central Florida
hasa68mustang
