Help with daily box in Maxima
notoriousroc1
MD
I am planning on running two 12" Type-R's ported at 33Hz in the trunk of my 2001 Maxima. If someone could design an enclosure for me, I'd greatly appreciate it.
My max external dimensions are:
39"W
16"H
15"D
Again, it's 2 12" Alpine Type-R's tuned to 33Hz, built for SQL. Thanks!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
make sure it will fit INTO the trunk and dont just take measurements of the inside thinking you can fit it... I just made that mistake //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Id go with 36x16x15 subs up with 2 4" aero ports pointing to the drivers side of the trunk. Place the enclosure as far back as possible. Thats good enought airspace for those subs should be good for both SQL and SPL might not do so good on the meter being tuned that low but will have a tight responce.
hmmm..it was either the 2 R's or one HDC312. its about 5 cubes gross though. I'm thinking the HDC might be better for this size???
and yes, this box size is the max of what would fit into a 2000-2003 Maxima trunk
1.75 ported is enough per sub for those 12s If you decide to go with the HDC I wouldnt do anywhere close to a 5cub box for it I would do a 1.75-2.25 with a 6" port ask Skip01 he did a box for 1 and it was not big at all mostly just big enough to fit the sub and port in..
i would prefer to build a slot box, cause the guy building it for me, will just cut the wood for $20 and help me assemble it. but if i could fit 2 r's with a aero port i think i would do that instead
Hey, I had 2 12" R's in the back of my '03 Max. I had them enclosed in a Q-Logic type 3 ported box (1.75L each side). It quaked! Sounded excellent too.
hmmm, thanks for the input. i won't be doing a pre-fab. but knowing that that size will fit is good. i'm trying to squeeze out all 5 cubes though.
notoriousroc1
notoriousroc1
MD
notoriousroc1
BP1Fanatic
BP1Fanatic
