help with constant noise
gilliethekid1
gilliethekid
so heres the deal i am having a noise problem not so much as a engine whine but more of a constant buzzing from speakers my set up as follows
hu-alpine 9885
-front ma audio 6.5 y630 comps
back-pioneer rev 6x9
sub- jl audio10w6
mono amp- alpine mrp500
4 ch rockerd ford punch 400-4
rockfors 2.0 digital hybrid cap
i just installed my new 4 ch ampa month ago when i did i noticed a very small constant whine form my soeaker niot sub just interior wise i have ran a returnground. grounded the chassis of amp as well as uninstalled all wiring and re ran everything new i have even raised my amp off of the back seat to avoid metal to chassis contact with amp i have done everything i know of to solve this expcept for a ground loop isolater i want to try and stay away from this cause its only a temp fix i have heard from fellow installers that newer rockerd amps and pioneers decks arnt friends but seeing as im running alpine im not sure what to do any ideas/help info would be great now all i can focus on is this buzzing sound and its really getting to me?
hu-alpine 9885
sub- jl audio10w6
Is it all speakers in the car? Have you checked to be sure the actual speakers themselves are not grounding out?
i have checked to see if the speakers are grounding it this just started when i put the 4 ch in on my old 4 ch it never did this i have exchanded the amp twice and it is still there and on the grounds i have removed all paint and used proper connections
have acess to a completely different 4 channel? try it, if the noise goes away, might be time to look into a different amp
lets see if it's the 4 channel itself do like never said if you have another amp available change it out see if the noise is still there if it is then they may illminate the amp. now we see if it's the rca's. run a different source right at the amp itself, like a portable mp3 player with a 3.5 to rca adaptor. that way we'll know if it's the deck, rca or in that area. if the noise is still there run a different power supply to the amp and see if the noise goes away then.
gilliethekid1
gilliethekid
gilliethekid1
san antonio tx
gilliethekid1
AJ (ACE)
    Jun 28, 2026
