Help with components......
Yeah I really mean it LOL ( as long as you arent going to recommend like some 18" Full range PA driver LOL).. More then likely I will do kick panels. Thinking of door pods but I think kicks may be better.
You think you can fit 8's or 10's in your kicks?
That would just make my day then B/c that would same some cash that can be put towards the mids/horns......
Double check the manual and check what xover points it is capable of. But it should work out perfect for you. Just make sure that you can go down to atleast 1khz on the highpass, and that you can bandpass the mids between ~60hz and 1khz. If it can do that, you're good to go.
8's more then likely yes without much trouble as long as they are semi shallow. 10's thats pushing it and is somewhat doubtful.....
**** looks like the HP for the highs only goes down to 1.6kHz. This means I would have to HP the horns @ 1.6k, Mids between 63 and 1.6 and the sub @ 63......Hmmmm
CELLERBR
CELLERBR
KY
CELLERBR
BP1Fanatic
BP1Fanatic
