Help with Big 3
You might want to e-mail Knu to make sure.
If I read it correctly. The posts you have linked are to mount the factory cables ends with a ring terminal mount added. I might be mistaken.
The cable ends you linked would work with side post to top post adapters.
There are also side mount cable ends that replace you factory ends with inputs of different sizes and use the factory bolt to attach them.
What are you trying to so, just extend the side mount bolt?? If so just go to advance auto or where ever and pick up the item in your first link ($2-$3 bucks).... the other terms. you linked look to be top only so without a new batt. and new ends on your OEM wires they wont work???
Hope this helps
old_greg
old_greg
Philadelphia, PA
______
