Help with Amp/Sub Combination
bl0ckd
is awesome like Obama.
Sub:
12" Kicker L5
Dual Voice Coils
600w RMS @ 4-ohms
1200w max
Would either of the following amps work for the L5?
1.
2 x 200 watts @ 4 Ohms
2 x 350 watts @ 2 Ohms
1 x 700 watts @ 4 Ohms Bridged
2.
500 Watts x 2 Output @ 4 Ohms.
1000 Watts x 1 Bridged Output @ 4 Ohms
no
your subwoofer is a dual 4
that means you an run it at 2 or 8 ohm.
trying to get 600 rms @ 8 ohm would be a waste of $
but 600 @ 2 ohm will be easy, and cheap
mhm
just go by this
500-700 RMS
2 ohm stable amp (to save you $)
fuse rating should be between 50 or higher or it ain;t pushing no 500 rms.
RMS power = Fuse rating + voltage (12.6-14.4)
bl0ckd
bl0ckd
Fort Wayne, IN
GAM3OVR
