Help With AMP in setup
ConceptRacing
16
STL
I have asked around before but i just want to get this straight, what amp would you guys recommend for these subs and what ohms do you think i should push them at 1? They are DVC subs.
First off don't buy volfenhag. It's a knock off brand that aren't any good. Whats the cost of 1? Also if you're only getting one, and its DVC 4ohm you can't wire 1 ohm!
I need to wire them at 2 ohms each, parrellel or series (I DONT KNOW WHICH) to get the best spl... ... WHAT MTX amp should i get for it?
First off are you getting the volfenhags?
Alrite if you wire the subs together you can get a 1 or 4 ohm load. If you buy a mono amp stable to 1 ohm you can wire to 1 ohm.
You can also wire the subs separately. You can wire each sub to 2 or 8 ohms. You will need a 2 ch amp for this.
Ok amp options for best bet
1. Mono amp stable to 1 ohm (wire subs together for a 1 ohm load)
2. 2 ch amp 2 ohm stable-wire subs separately and have a 2 ohm load on each sub
ConceptRacing
ConceptRacing
STL
DaBaller504
