help with a RLP-12 ported
LowLinc
heres what i have:
RLP-12 (D2) in a 1.75 sealed box running off a us amps 50-HC (375rms @ 1 ohm underrated) its in the trunk of a 88 tercel.
i want to build a ported box to get it louder but still retain most some of the SQ.
can someone help me design a ported box for this? should i port it thru the rear deck? i have 15" of height inder the rear deck and 24" between my rear speakers. depth doesnt really matter.
here are the specs off soundsplinter.com:
Dual 2 Ohm
Qes: 0.226
Qms: 2.470
Fs: 23.43 Hz
Re: 3.7 Ohm
Ls: 4.060 mH
Rp: 7.478
Vas: 87.73 L
Mms: 177.9 g
Cms: 259.2 u
Bl: 20.70 T*m
SPL: 88.81 dB
Sd: 0.0471 m^2
Xmax: 24.2 mm
Displacement .15 cu ft.
moe lesters plans for 2 cu ft at 32 hz plans 1 and 3 fit my trunk. the only difference is the port volume, 24 or 30 sq inches. which would suit the rlp better?
LowLinc
LowLinc
Oxnard CA
LowLinc
