help with 4 CH SQ AMP
KS 300.4*| Arc Audio
it dont get much better than this. rated at 12.5 volts. you can expect to get about 110 or so at 13.8. class H too so its nearly as efficient as class D without the drawbacks. its a class H. the thing is on these designs you need a high slew rate and good fast swiching. which arc of course didnt leave out :0.
Z-150.4 - Zapco 4-Channel 1000W RMS Class A/B Z Series Amplifier
abit over priced but still a great amp no doubt..
SYN 4 - Wet Sounds 4-Channel 800 Watts Amplifier
XL-150c4 - Gladen 4-Channel Full MOSFET XL Series Amplifier
noting super special just good parts..
MMats SQ4160 4 x 160 at 4 Ohm Audiophile 4 Channel Amplifier
Ive had good luck with ARC amps, nice sounding and solid power. Zapco as stated is expensive, but also great performers. I personally dont care for class D amps when doing mids/highs. Ive noticed class AB has a warmer/fuller sound tobthem over class D. I know people will argue that, but its only bc they are running class D amps with some expensive sound processing on top of everything.
greenthumb1
greenthumb1
hawaii
mylows10
vegang
vegang
