Help with 1996 Crown Vic wiring
  • 2
I'm putting an aftermarket head unit in a 1996 Crown Victoria--or at least trying to. I cannot find the proper adapter harness to connect the aftermarket radio to factory wiring.
The stock radio has 2 plugs going in the back. 1 is the standard gray 8-pin Ford that's used in numerous models and is easy to find. The other is this weird little 16 pin plug that only uses 8 of the pins. Images attached.
I've taken this car into numerous car audio places, asked Crutchfield, and no one seems to know where to find a harness that fits this thing. I was recommended numerous Metra harnesses, but nothing has fit. Note the placement of the receivers for pins connecting from the stereo/adapter.
Car info: 1996 Crown Vic, base model, no premium sound system, no factory amplifier.
Any help or recommendations is appreciated.
My Vic is 05 and had a large plug then a smaller plug. I only need to utilize the larger plug. This could be your problem here. You only need to connect the 1 plug
I tried that method, but the 8 pin gray only supplies power to the head unit. I could load CDs, connect Bluetooth, control the dimmer, and so on, but without the 2nd plug, I got no sound.
172
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
190
423
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
268
DIYing but kinda dying
Alberta, Canada
Ripkon
    Apr 26, 2024
    Apr 26, 2024
