Ok so i have.....
Infinity 692.9i
Handles up to 330W peak power (110W RMS)
6" x 9"
Impedance: 2 ohms
Infinity 6020cs
Handles up to 270 watts peak power (90 watts RMS)
6-1/2"
Impedance: 2 ohms
and has a crossover connected to two tweeters.
Rockford Fosgate P200-2
50x2 @4 ohms rms
100x2 @ ohms rms
200x1 @4 ohms bridged rms
I know Infinity and Rockford is considered more of an amateur brand but i bought each pair for $90 each brand new and the amp for 80 brand new... I didnt think it was a bad deal but anyways... BTW keep in mind im only 17 working for $7 an hr and no my daddy isnt rich.
My problem is i want to hook both sets upto my amp. The amp is already hooked up and everything with the GND REM and B+ wires all where their suppose to go(i think anyways as the amp worked with a sub).
So from what ive researched is that if i hook both sets of speakers up into Series using 16 gauged wires and plug each sets of wires into both channel as in making it 100x2 @ 2ohms as in bridging it but using 2 sets of wires.... Then that should work? Also when im talking about "plugging in" im not talking about the speakers themselves but the crossovers.
Also my head unit a Kenwood eXcelon KDC-X579 has preouts for the front and the rear and another one I think that is for subs? So how would i go about connecting both of the rca connectors ie. front and rear to the one set that is on my amp.
Ok so a run down
Will the connections from my speakers/crossovers to the amp work?
How can i hook up two sets of rcas to one set on the amp?
Incase ur wondering why im doing this...If u dont care and just wanna help with my above then skip the rest.
But anyways I think the amp on my head unit is messed up cause suddenly everything, all of the sound just cut out one day and i could only hear the base from my sub. What i did was unplug my amp rcas from the head unit and then the wires at my 6x9s. Then the front left side turned on. So i was like ok.... then i plugged in the back right and that one turned on... so sweet right? then i plugged in the back left positive and the speaker turned on then i plugged in the negative and everything cut out which is wierd... All the while the front right wont work at all. Im basically lost with this problem plus ive been wanting to hook my speakers up to my amp for awhile now so this is basically pushing me to do it. Y
Yes i did check to make sure ALL of the wires where connected and what not.
Thanks for reading and i hope I get some good replies and once i have this figured out ill probably ask more questions about a future plan i have brewing lol.
Infinity 692.9i
6" x 9"
Impedance: 2 ohms
Infinity 6020cs
6-1/2"
Impedance: 2 ohms
50x2 @4 ohms rms
100x2 @ ohms rms
Ok so a run down
