funkman262
Hey guys, I'm wanting to install a Pioneer FH-X700BT into a 2003 Grand Am GT, and in order to keep the chimes I'm also wiring in a GMOS-04. I've never installed a stereo before, and I think I understand what I need to do, but I would like to verify before going ahead with the install.
The radio harness has 2 each white (front-left), gray (front-right), green (rear-left), and violet (rear-right). It also has a red (ignition switch), black (ground), yellow (12 memory), and blue/white (amp). The 16-pin harness on the GMOS-04 has all of those but the yellow and black which are on the 24-pin harness.
So there's a few things I'm not positive on. The 16-pin harness has two red wires, and then another one coming from the 12-pin harness for ASWC (but I don't have radio control on my steering wheel). Do I just connect the two red wires from the 16-pin to the red wire from the radio harness? For the ground, I believe I'm supposed to connect the blacks from the 24-pin and radio harnesses, then screw that into the metal frame under the dash.
GMOS-4
16-pin
That loose black/yellow wire is for Onstar volume control, which I don't have.
24-pin
Top-to-bottom loose wires: black, yellow, orange/white, orange. Do I need to do anything with the orange illumination/dimmer wires if they're not on the aftermarket radio harness?
There's the other red wire I was asking about. I also don't know what that plug is for, but I'm assuming it doesn't apply to my system.
Radio harness
Is there anything else I'm missing? Do I need to hardwire into anything else in the car? Am I supposed to cut any wires? I know I sound completely clueless, but I actually love to DIY and learn as I go. Thanks for reading //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
GMOS-4
16-pin
24-pin
Radio harness
