HELP!! Wiring 2 MA Audio subs to 1 Mono Kenwood Amp!?!
Otter_Andrew
Hey, I've got 2 dual 4 ohm MA Audio 600 Watt Subwoofers and I just got a Kenwood Excelon 1200 Watt Mono Amplifier (KAC-X10D) and I'm wondering what the best way to wire these would be to get the deepest, loudest bass!? Also, I was under the impression that a mono amp would only have 1 channel out, but there appears to be two, can anyone explain this to me?
no not all mono amps have only 1 channel output there are alot that are internally bridged, that kenwood amp i dont think is 1 ohm stable so your going to have to wire each speaker in parallel so it owuld be at 2 ohms
It is 1 oh stable?
if it is which I still am not positive on.
Then just connect all 4 positive to the positive on the amp and all 4 negs to the negative on the amp that would be 1 ohm.
It only has one channel, with two sets of connections.
Think of a wire splitting into 2, now shove that into the amp, and just have the 2 ends coming out. They look like two different connections, but its the same thing...
You cannot achieve a final load of 2 ohms with 2 DVC 4-ohm speakers.
Yup.
Otter_Andrew
Otter_Andrew
Orem, UT
ultimate157
