HELP!! Wire 2 dual voice coil subs to 1 2 channel amp?!?!
Wire both subs to present a 4-Ohm final load and bridge the amp or wire the coils in parallel and give each sub it's own channel. Either way ends up with the same power to each sub.
-Bill-
Sorry, I'm sort of car audio illiterate, so are you saying that I should just use one channel for each sub, and wire both voice coils to the same channel?
If you want to run each sub to it's own channel, you do this:
If you want to run them at 4-Ohms, bridge the amp and wire them like this:
-Bill-
what if u bridge a 2 channle amp, and splice 2 wires coming out of the + and 2 wires coming out of the -? then do what is done on the first image?
if i correctly follow you, that will create a 1ohm load on the amp...not good if its a 2ch
Otter_Andrew
Otter_Andrew
Orem, UT
kr15
