HELP - Wich is the best option?
Diamond Audio D661s
Power Handling NOM/MAX: 200 watts MAX, 100 watts RMS
Sensitivity (2.83V/1m): 90.6 dB SPL
Freq. Response: 45-22
Type: Component
Kit Includes 2-Midranges, 2-Tweeters and 2-Crossovers
Mounting Depth/Diameter: 2.7 in. / 5.8 in.
Silk Tweeters
Kicker Car Audio 05C12-4
12" subwoofer with high-strength steel basket
Polymineral cone with double-stitched foam surround
Power Handling Watts, Peak (RMS) - 300 (150)
Sensitivity [sPLo], dB @ 1W, 1m - 89.1
Effective Frequency Range, Hz - 27-500
Mounting Depth, in (cm) - 5 3/4 (14.6)
Hole Cut-Out Diameter, in (cm) - 11 1/8 (28.3)
Equivalent Volume [Vas], ft3 (L) - 4.50 (127.65)
Net Displacement, in3 (cc) - 104.9 (1718.6)
Moving Mass [Mms], oz (g) - 4.01 (113.57)
Magnet Weight, oz (kg) - 45 (1.28)
i´thing that Phoenix Gold Octane 5.0:4 is a good option.
Thx
Phoenix Gold XENON 200.4
variable thermal feedback controlled fans
24dB Linkwitz-Riley low pass and subsonic filter
optimized for any impedance load
Tried and true triple Darlington output stage
Buffered RCA full range thru output
Remote Monitoring Display (RMD) port
Low Pass Level control ready (LPL-44)
200W x 2 (4-1 ohm stereo)
400W x 1 (8-2 ohm bridged)
CEA-2006 approved
Phoenix Gold X100.4
100W x 4 (4-1 ohm stereo)
200W x 2 (8-2 ohm bridged)
or another economic option?? ;-)
podesteando
podesteando
BA
podesteando
