help!! vr2000d won't play music
You said you changed the wiring from the subs to the amp, I would check over those wires again, How did you wire them, did you hook up both voice coils correctly, tell exactly how you wired it
that was the last thing i need to check. but i'm still reading two ohms at the amp so i'm guessing they are still hooked up right.
i have possitive coil one to neg coil two on both subs hooked up then since the amp has two possitive and two neg ouputs i wired one possitive and one neg to one sub and they are connected at the amp so it wires it to 2 ohms.
i hope i explained that right
does anyone know what it could mean and why the protect like comes on first for half a second then the green like comes on like everything is fine??
omg this make no sense what so ever!!!! i had checked everything fliped every switch each way play with all my filters and gain and everything and nothing was working at all. so i opened it up again and had my dad look at it cuz he has a degree in eletronics just to get his opinion on one spot that looks as if it could be fried. well we tested it and it wasn't fried. so i put it back together and put it in the car again for the 5th time or so. hook everything back up and still nothing plays so i just start playing with all the filters and gain and all that stuff again for the 3rd time and when i flip the sub filter on the amp to off it start playing!!!! i had flipped that 2 other times already and nothing had happed!! i don't get it. but now what i flip it on or off the subs still work fine no problem what so ever.
thats for the help guys. i feel like a total dumb *** now. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Too many posts to read here, so sorry if this was mentioned before. I would take it down to bare bones and go step by step over each and every wire to make sure you have it all connected right. Disconnect the subs and the RCAs and see if it still goes into protect mode. If it does, then it is probably damaged. If it does not go into protect mode, then you had something wired wrong.
thanks for the help man but i've got it fixed now. i did that three times and it did nothing. but in a way it kinda fixed itself i guess you could say or i just got lucky
tsupra98
tsupra98
waco, tx
tsupra98
