Help!!!!!!!!!!! Urgent
nebstewart07
MO
I have 2 dhd 600 watt subwoofers. What size amp would i need. How good would a 300 watt amp fusion encounter perform and how much are they worth. I need to know asap. Thank you very much. Eventually i am planning to have 2 more 12s in there. if that helps. Can i hook all four subs up to one amp. Should i get a 4, 3, 2, 1, 5 chanel amp? What is the differance. I talked to one guy and he said that i should hook up my speakers and my subs to the amp. Is that a good idea??
Thanks,
Nebstewart07
is that max or rms rating on the sub and amp, i wouldnt go with fusion though, i hear they break all the time. and if u get 2 more subs, you can run them all off a mono amp, just make sure it can take the impedance ud be wiring it to. and putting your speakers on a mono amp is a BAD idea, id get a seperate amp for the speakers
nebstewart07
nebstewart07
MO
mtlhead
