*HELP* Troubleshooting saz-3000D protect
  • 4
Rawr-DQ
!!!!Vote Third Party!!!!
unfortunately, after re-installing my car audio I found my sundown amp going into protect.It goes into protect immediately; the power light turns on about 1-2 secs later; 5 seconds later the two relays marked with a purple X close/open(click)...; unhooked from speaker; I found manufacture damages that were covered in glue, marked in black; red. In pink there is some rubbing damage to the winding; no metal caps blown; the plastic ones which the top may have some give; each one can depress at-least a mm or so. That's all I can tell visually. I cannot smell burnt electronics; nor are any burns prevalent on top of the board.I've built small circuits and studied them a lot; and have a megger which probably wont be needed; along with a 400mfd/~2Mohm range; and MV Meter... I also have an oscilloscope. So please help get me to a starting ground on repairing this amp; I have good soldering skills. And can re-paste the transistors tot he heat sink with high quality thermal compound.Pictures are large for detail...
yellow rub; black manufacture damage
all manufacture damage; have glue over it; yellow insulation missing on wire; black minor heat shrink overheated.
X's represent relays turn on/of after 5 seconds.
In yellow rub; pink manufacture damage
I did some testing; I have a 12v powersupply thanks to a optima d31a; 1125 cranking amps; 900 cold; 75 amp hour battery just sitting around...I did millivolt testing From the positive terminal; I can measure hundredths of a millivolt; I got ~29mv on exposed windings closest to the power in. ~5mv on each heat sink. marked in green I have 102 volts.Any ideas where to start; can someone help me trace the protection circuit?
Strong odds it's something that has nothing to do with what you have pictured. Any semiconductor on that board could be hosed and not appear visibly damaged.
well I don't mind pulling and testing them. But I need a basis on how the protection system works; and how many variables, chips, and circuits could be involved?
I have 102 volts but no power out and don't know if the protection system is analog or digital, however I don't see many chips and will probably pull it and check every transistor for cracks or other overheating damage
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
69
582
576
Rawr-DQ
Rawr-DQ
Fort Myers, FL Posts:____________31,337,666,999
Timmothy Web
