So which amp to get?!
JoshGuy
i plan on running a single SA -12 at 2 ohms off one of these at first and then later on possible buying another SA - 12 bridging the two and running them a t 2 ohms together off one of these. Which one do you think would be more effective overall? Which one has a better rep? Thanks!
http://www.amazon.com/Hifonics-Hfi2000d-Watt-Block-Amplifier/dp/B003PSAQXA/ref=sr_1_sc_1?s=car&ie=UTF8&qid=1322419954&sr=1-1-spell
Amazon.com: MB Quart ONX1.1500D Amplifier 1 x 500 @ 4 OHMS, 1 x 1000 @ 2 OHMS, 1 x 1500 @ 1 OHM: Car Electronics
Yes, Those S Stream amps, have better specs. I use old school amps, never have used any of the amps mentioned, but the specs on the Streams are really good.That Rubi should be a real Banger for those subs!//content.invisioncic.com/y282845/emoticons/iagree.gif.15d6c075ee8d3913ba26866d06993068.gif
i've installed them in a couple of my customer cars ,and i dont think they are all that .to get them loud you have to turn up the gains way to much for my liking .never had good luck with hifonics or mb quartz either .but thats just my .02
wait? how would you get 2 4ohm subs wired together at 1 ohm? if you run them both parallel the lowest your going to get two 4 ohm subs is 2 ohms??? if you wired 2 2 ohm subs together in parallel you would then get an end result at 2 ohms? am i missing something?
S Stream amps specs are pretty darn good.Check them out, and compare to the other amps??They would be a choice made for myself other than the PPI Sadona amps, would be my second choice, yet, I m not in the market for any amp at the moment.Not only that, but what a hell of a warranty????//content.invisioncic.com/y282845/emoticons/boink.gif.91933e72f927f2cefc79aff02573090c.gif
JoshGuy
JoshGuy
Lawton, OK
CAT MAN
