Help, System Sounds Like Crap
Mattism78
I just purchased a box/subwoofer off of ebay. Everything seemed on the up and up. After the setup arrived I went ahead and hooked everything up. Sounded great at low levels, but as soon as I started turning it up the bass started bottoming out. Could it be that my box is too big? I'm running a JL 10W3V2, with a Kenwood KAC8402 running at 3 channels. I would think that it would barely have enough power to push the speaker to it's full capacity, but it's bottoming out. The box that I have's dimensions are:
Bottom depth: 11"
Top depth: 6.75"
Width: 35.5"
Height: 10.25"
It's 5/8 MDF.
It's installed in my Jeep wrangler firing downwards. I'd really prefer to get it working right as opposed to buying all new amp, sub, and building the proper box. Is there a way to fill some of the interior space of the box? Is it needed? Any help would be GREATLY appreciated. I'll attach some pics as well. Even just looking at it, it appears to have entirely too much airspace.
Man, why don't you ask what dimensions the box *should be* rather than just chopping it in half? It sounds like crap because the enclosure is wrong.
So, you need the right enclosure. Let us know what the specs of the new box are and we can tell you if it's optimum.
So you used no math or calculated the internal volume you're saying? This is what I'm getting at.....JL subs sound the best in their recommended size enclosures. Just because it sounds better doesn't mean it sounds best.
I don't feel like doing the math, but you can go to http://www.the12volt.com and plug in the numbers in the enclosure calculator to get your totals, or multiply the INTERNAL dimensions and divide by 1728.
The trimmed box has 0.675sq ft. If you figure the speaker displaces approximately .05, I'm within .04 of JL's recommended airspace. I polyfilled the box to make up for that.
Sounds good man, just wanted to be sure you were aware of that for the next time you may do an install. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Mattism78
Mattism78
Vero Beach, Fl
Mattism78
vegang
vegang
