Help! SPARK
keeb
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif I think my whole system may have just short circuited. basicly i was unscrewing the remote wire (going to my headset) from my amp, it sparked and everything turned off. my headunit doesnt turn on! what should i do?
make sure nothings on fire
THIS is why you fuse the REM wire. Sorry, check the fuse on your HU. It may still be blown.
yup...
when will people realize that the first step in working on ANY part of your cars electrical system/Audio System is...UN-HOOK the BATTERY.
i hooked up amps with the battery hooked up tons of times never blew nothing
I was unscrewing it because my amp is always on no matter what, and before you say anything i know correct way of wiring it on the headset, its been done before but it then doesnt turn on at all. I got a pegeout 206 btw!
how do i check the fuse on my headunit? and my amp doesnt turn on either!
then you weren't using the correct wires. There's a remote wire from the HU AND there's the ignition wires on the vehicle that can be used.
Yep i know, i got a professional to check it out, and he told me to ring some other guy beacuse he had no idea why the amp didnt work when it was wired correctly!
keeb
keeb
london
SyKo13
