HELP! short circuit or pinched wire?
sooo i had a stock Mach460 system. blew out my right doors 6x8, bought a pair of pioneers 240watt max. replaced my blown right and my still good left. i thought everything was peachy.
not quite everything though, my mids in the front work fine under all loads, my reaer 6x8s on the deck work fine also as usual. BUT! the newly installed pioneers will only play under a light load. say volume halfway up or so and bass halfway up. if i turn up the bass to its normal or crank the volume to where i always listen to it, the pioneers cut out. when i turn the volume or bass down, they kick back in.
question here is...now what. i ran a resistance test on the left doors wires, gave me 4ohms. from my basic knowledge of electricity this is bad? as in a short or something right?
it could possibly have a built in protection circuit.... but thats only operational until the speakers break in and that would be about 20 to 30 hours of playing music really low
so by then you shouldnt have a problem...but don't do it while the cars not on , youll drain the battery even if you have an alternator.. everytime you go for a drive just play music
Bumps_N_daTrunk
Bumps_N_daTrunk
Fort Myers
Willkas
