^^ I like this guy. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifif you want cdt's, i suggest the hd-62, you can get them for around 320 from djdilliodon, i'd suggest rainbows SLCs, save yourself some money.
The speaker FAQ. Ingenious thread.2-Way vs. 3-Way
In a perfect world, we'd have a single speaker that could reproduce all frequencies perfectly, 20hz to 20khz. Unfortunately for us, such speaker does not exist…..so, we need to break the frequency spectrum down and play it through multiple speakers (mids, tweeters, subs, etc). This is where we get "2-ways, 3-ways, 5-ways, etc" from.
In co-axials, a 2-way speaker is a speaker that contains only a midwoofer and a tweeter…..the midwoofer playing the lower frequencies (down to around 80hz or so), the tweeter playing the higher frequencies (around 3khz or 4khz and up). 3-way co-axials typically have a midwoofer, tweeter and "supertweeter", with the supertweeter being designated to handle the very, very high frequencies only. Co-axials can go as high as 5-way (midwoofer, midrange, smaller midrange, tweeter and supertweeter). For all intents and purposes, anything more than 2-way in co-axials is a marketing gimmick. Going with 3-way co-axials or higher usually does not increase performance much, if at all.
For component speakers, a 3-way system includes a dedicated midbass (generally plays around 60hz-350hz), a dedicated midrange (generally plays around 350hz-6500hz or so), and a tweeter (generally 6500hz and up). Whereas a 2-way system is only a midwoofer (playing around 60hz-4000hz or so) and a tweeter (4000hz and up). Ideally, for a 3-way system, you'd want to put the midbass in your door, and have kicks built for the midrange & tweeter. For a 2-way component set, kickpanels or door mounting will suffice with generally good results.
General advantages of a 3-way component set:
1) There isn't a crossover point in the middle of the midrange frequencies (which are generally the most important to imaging and tonality), and they aren't being split up between drivers like they sometimes are in a 2-way setup. In a 3-way, they will be played by mainly one speaker, which is the dedicated midrange.
2) In a lot of cars, the mids will need to be flipped out of phase to help correct some midrange frequency phasing problems. In a 2-way system where one speaker plays midrange & midbass, running one of them out of phase will decrease the midbass impact. By running a 3-way, the midrange can be flipped out of phase and it has no effect on the midbass since it is being played by a separate driver.
3) The midrange and midbass frequencies in a 3-way may sound "cleaner" since each speaker has more of a limited bandwidth to play.
Disadvantages of a 3-way component set:
1) Tuning and aiming the speakers can be a much bigger pain the *** with 3-ways. Installation, tuning, phasing and aiming speakers will be much easier/quicker to perfect with 2-ways.
2) Room. It can be much more difficult find the room to fit all of the speakers. In some cars, kickpanels are simply out of the question.
3) Money. 3-ways are normally considerably more expensive than 2-ways.
As you can see, 3-ways aren't necessarily better than 2-way. It's more of a personal preference. Some ppl would rather have a 3-way (for the advantages above), some ppl would rather have a 2-way (easier to tune, less room is occupied, etc).
From the modified list, I would choose the Diamond Hex series first, then the Rainbow Germs (price wise), but IMO, the Polyglass comps aren't in the same category as these. If anything the 165KP's...the KF's are good, better than the polyglass, but the tweeter is the TN47 and it is Shrill, the KP's have the new TN52 and that tweeter is much, much better. Same tweeter in my K3P's.
Thanks for the honesty 6spd, I read in another thread that since the company Eaton stopped making the HEX line of Diamond they have slipped a bit. I know your biased toward Rainbows but who can blame you to throw props to what seems to be the hottest thing on the market.
The SLC 365 KICK @ $400 is the best recommendation I've heard yet but I have two questions.
1) What set-up will have them function at thier best? Can I put the midbass in the door, tweet in the door pillar and the midrange alone in the kick for above average results? That would be my most resonable set-up for my ride.
2) "**System has to be used with an 80 Hz (12 dB/Oct.) high pass!
System needs approximately 10 hours running in time for optimal sound reproduction." I understand the second part of this statement, break-in time. But the 80hz high pass, does this come with it? Where to get it and how to hook it up (newb)?
Of course my rear fill need against most saying no! The SLC 265 in the rear deck? $229
I guess I'm not really on the coast line. A little bit more inland. I live in the South Hills of Pittsburgh.
Since you know the Alty fairly good do you think the SLC 365 KICK or the GERMANIUMS are the way to go? You can see I'm willing to dump a little money here and the differance would be about $50.
What type of issues may I run into with depth of the midbass in the stock door location? And what are the size of the front door speakers. By the looks of the grille on the outside of the door they look 5 1/2 but I'm sure I'll find a 6 1/2 inside. No biggie either way, I can build and install my own baffle but its depth that worries me. A friend and I noticed that the doors are a bit on the thin side.
Lastly, what model coaxle would do the think? Of course I'd like to stay brand worthy thru and thru.
Anyone else wanna put up a fight against the Rainbows. I know this thread started off as 2-ways for $300 but It's gone to about $550 - $600 for 2 or 3 way front comps and a rear coax.
I listen to hip hop mostly.. OutKast, Gnarls Barley as of late. I have a wide range of taste from Rage against the Machine to Incubus. SUBLIME might be the greatest band of my day. I think if I had to select a type of music to hone my speakers to it would be a jazzy hip-hop where the instruments can be bright but not too bright. I like to feel the incorporated drums but don't want the lows to overcome the mids and highs.To narrow down choices a bit..what are your musical preferences?
Do you typically play loud?
What amp(s) will you be using?
Im guessing youll be running passive?
I will be running a sub eventually and will have the ability to shut down any channel from the HU. But I would think that a 2 or 3-way for the front and a coax in the rear(prolly around a 6.5") should give me a wide range of frequencies. It better for the $600 or so I spend on just speakers. I just expect to be a little short on theid say go powerline cmx rainbows and then a decent pair of rears. Do u plan to run a sub, if not i suggest some 6x9's for some lows and decent mids.
Uhhh or you could go germaniums 2 ways with a 2nd woofer in the rear spot?
Mike
