help RCA Q?
  • 2
micro4hard
miami
new here i am not an audio experet but always had my nice soundidng systems in all my past cars, i just got a new car and would like to get this head unit double din Eclipse cd1200g, the problem is it does not have a sub out only frnt and rear rca's. My questions is could i do with out sub outs and use rear rca, i looked for awnsers but found nothing and for the price and brand is to good to pass, please explain kinderganden style any soulutions as i know how to install but have done it very little, i also just like right amonut of bass nothing crazy but clean bass to complement tracks, the amp used will be a small punch 200-2 with a 10" pioneer but lately have been considering a small 8" inside the cabin any thought on this thanks
Yes you can us the rear. but I would suggest getting a bass maximizer or similar xover / eq thingy.
Amazon.com: Brand New Clarion Mcd360 3 Way 6 Channel Electronic Crossover w/ Subwoofer Control: Electronics
the problem is that before purchasing one of those i could get a radio for that kind of money that has sub out, i read somewhere that you could mix both frnt and rear and get a sub output with y cables how does that work?, also does i think the amp has crossovers , does in it? thanks for the quick replys looks like i came to the right place for advice
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
985
520
micro4hard
micro4hard
miami
micro4hard
