HELP QUICK can i ground here? *Pics*
trevor87
Can i ground under that bolt? the bottom black piece is metal. Dont have any more wire to run to neg on batt.
Also ill be using a LOC until 2moro can someone tell me where i can run the remote wire to something that will turn my amp on in a grand am gt?
ok thanks guess i wont mount there......i need a screw of some kind but there is nothing in the trunk thats metal and can be clamped down........unless i drill a hole in the floor and mount a screw and bolt.
whats wrong with grounding to a shock mount? I've got a grand am as well and that looks similar to what I have my ground to. Btw Is running ground to the battery a good idea?
Whats wrong with the shock mount as a ground? I have a grand am as well and have a ground to a similar spot like that. Btw is it best to run a wire to the negative on the battery?
Best ground there is.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
trevor87
trevor87
GEORGIA
Raisedin305
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
