Help please!
  • 1
L1ttlet
CarAudio.com Regular
165
HELP! So when I turn up my bass to loud my mids n highs amp well go silent (won't play for 3-20seconds) also sometimes when the bass is hitting hard I will get a loud popping noise coming from my super tweets in the doors I believe it is ear piercing.
The setup is 2 wolframs 6.5's on 250watts rms at 2ohms per channel 3 and 4 running active. Then channel one and two same thing but for the wolfram super tweets, and both are tuned where they need to be and gains set with dmm correctly. They are being powered by the wolfram 250.4 which has a clip indicator and they are seeing clean power, no clipping and amp isn't turning off when they do quit playing. Again it only happens when bass is hitting well. Have a 4500.1 that nvr skips a beat, both amps are mounted to same amp rack. I don't let voltage drop under 12. Both amps have the knuconceptz rcas(heavy duty one)
My thoughts are either a bad rca or maybe the tweets are hitting the metal in the door panel as I literally had to grind a out some door panel to make them fit. I'm at a loss right now, I'm think those two or a bad amp. Any input would be greatly appreciated, thank u.
If I turn bass down I can crank mids and highs amp without a single issue all the way up to 28 on my headunit which is the point before clipping.
893
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
884
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
L1ttlet
L1ttlet
L1ttlet
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
