[HELP PLEASE]Wire disconnected, can't figure out how to disconnect battery.
  • 6
FamousMassacre
Team Tantric
I noticed that my (amp?) wire disconnect from it's terminal.
I can't find my negative connection, I'm thinking that it's here:
Car is a 2012 Ford Focus
Help! I'm afraid to even turn my car on now haha
Or could I just unscrew the terminal and clamp it in?
Do I need to disconnect my battery?
If the vehicle is drivable,id take it to Orileys, or Autozone/or Napa, and get them to test the batt out, and tell you which is your +,and -.Its free,and Id do since you are debating about it.I cant really tell from that pic
Well, the left side is a positive lead because there is a + on it.
I couldn't find a - and I was thinking that the wire was the ground to my amp and is connected to the negative.
neg should be near your amp. the terminal clamp in the pic has a + on it
I just noticed that in the pic too..Even that wire not connected should be a + wire,generally being RED,and that close to the Ring terminal attatched
Fuse holder that goes back to the amp. Thats your positive power to amp. The negative connection you need to trace from the negative of the amp...
Now I wish I installed my system haha
I'll look for it tomorrow when there is daylight.
Is it safe to turn on my car?
Hell, could I just get pliers and open the terminal and connect it while it's connected?
After looking at both pics,Thats your power feed to your amp that is not connected to the battery.Take the ring terminal off the batt, and reattatch it to your wiring/crip it back in place with Pliers as you say, and use electrical tape on the wire/terminal.Then you can reattatch it to the battery,..Just make sure the wire on the Ring Terminal is going to hold tightly..I dont use those type of ring Terminals,They seem to never hold the wire tightly.I use Copper Ring terminals,softer, and easier to crimp,and hold the wiring much better
it will be alright to drive. pull the fuse and disconnect the wire from the fuse box and take it to a audio shop and have them crimp or solder a new ring terminal on it
946
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
913
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
FamousMassacre
Team Tantric
FamousMassacre
San Antonio, Texas
NJTStang11
Brendon Jenness
    May 8, 2024
    May 8, 2024
