Help please! Kicker amp
  • 4
Ruffin90
I have a kicker cxa600.1 mono amp.
Everything was working fine for a month or so and then my amp went into protection mode. I checked all wires and my alternator just in case and everything is fine.
When I start my car it is solid on red and a few seconds later the green light starts to flicker rapidly but won't stay on.
I had it tested at audio express and they said it worked great with no issues.
I installed back into my car and got the same problem.
I fixed my ground on a factory ground post with a 12 inch ground wire.
Ground is solid but still having issues
I checked with multimeter and it has 12 v off but 22 v when car is started. I'm pretty sure this is supposed to be around 14 when car is on.
I have recently replaced my car battery of this at all helps.
Please get back to me my car soundso so shifty without my dogs barking?
No I checked the power cable I took speakers out because there were in my way.
But it's in protection even before the input is connected. All I had in was power remote and ground. It shouldn't be in protection mode even if the speakers are not in yet. It should still be lit green
that 22v power reading is suspect. Waaay too high.
The newly installed battery may be the issue.
Measure you're dc voltage with the car running at the battery terminals.
If it's a lot more than 14.4-- you have a charging system issue.
Update
That was due to a setting on multi meter. When checking it with DC the battery is putting out fine at 14.5 but the amp 12v is getting 10.8 something. Not enough
What else could it be I have read grounded that thing like 5 times because I thought the same thing I have never had an issue grounding before
OK I feel dumb now........
Fuse was bad.
Took multimeter and checked both ends. One side read 10.8
Replaced fuse and worked great. I went two months without my subs and about 200 dollars rewiring several times over a 4 dollar fuse.
Ugh
Thanks for your help brah
That's awesome. I used to be big into car Austin the '90s. Since then I have always had some sort of mild system for my wife's vehicles, but...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
Ruffin90
Ruffin90
Pho, az
Boomin_tahoe
    Jun 15, 2024
    Jun 15, 2024
